September 29, 2015, 12:44 |
velocity profile at a ducted turbine intake
Hi Colleagues,
I’m just a beginner, learning through the tutorials and trying to duplicate the analysis I see in the research papers. According to the theory, wind flows can be concentrated by duct, thus the wind velocity can be increased. This is proved in a study, by simulation. My simulation is completely different and I want to know the reason. Here are the dimensions of duct: https://drive.google.com/file/d/0B6W...ew?usp=sharing Here is the simulation result of the study (velocity profile): https://drive.google.com/file/d/0B6W...ew?usp=sharing Here is the simulation result of the study (pressure profile): https://drive.google.com/file/d/0B6W...ew?usp=sharing In my simulations, the projected air flow does not completely get into the duct; instead large amount of it flows around the duct. Since, only small amount of flow flows into the duct, the velocity at the ‘intake’ is much smaller than the actual wind velocity. I’m not really sure, - if I define wrong boundary conditions or set wrong simulation settings - if the simulation in the research paper is wrong (probably not :P) The settings I used in simulation: - Analysis Type: Steady state - Material: Air Ideal Gas, Pressure: reference pressure 1 Atm - Inlet domain-> Normal speed: 4m/s, - Outlet domain-> static domain, relative pressure: 0 Pa - Wall domain-> No slip wall, roughness: smooth wall Here are my simulation results: Pressure: https://drive.google.com/file/d/0B6W...ew?usp=sharing Velocity: https://drive.google.com/file/d/0B6W...ew?usp=sharing https://drive.google.com/file/d/0B6W...ew?usp=sharing https://drive.google.com/file/d/0B6W...ew?usp=sharing https://drive.google.com/file/d/0B6W...ew?usp=sharing https://drive.google.com/file/d/0B6W...ew?usp=sharing Thank you for your dear comments, Caja. |
September 29, 2015, 20:02 |
Rep Power: 143 |
That is correct. The throat causes a high pressure region and the high pressure pushes air to the side so less air goes into the duct. This is all as expected. Your theory is going to have to account for this air which doe snot pass through the duct if you want your theory to be accurate.
cfx, concentrated, ducted, shrouded wind turbine, wind |
Shear stress from velocity profile | baranii2000 | COMSOL | 4 | November 11, 2015 04:08 |
Patch fully developed velocity and turbulence profile over full domain | Teumde | FLUENT | 2 | June 29, 2015 13:47 |
Velocity profile interpolation FLUENT | Mustafa1986 | FLUENT | 3 | April 28, 2015 03:23 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
particle velocity and velocity profile | HGG | FLUENT | 2 | June 10, 2001 16:32 |
