Determination of the induced Drag for a rectangular wing |
April 9, 2015, 13:11 |
Rep Power: 11 |
I am currently working at an Optimization for Wingtip Fences for a rectangular wing in subsonic (incompressible) flows. For my seminar paper one task is to determine the separate drag forces. To determine the induced drag I watch the losses of momentum in the control volume. Di = [(Pressure@IN)-(Pressure@OUT)] dy dz = 0.5*(Density)*(v^2+w^2) dy dz Expression in Post: "0.5*Density*areaInt((Velocity v)^2+(Velocity w)^2)@OUT" where v and w are the induced velocities in a yz-Plane (Trefftz), very far behind the wing. I have observed, that the viscosity of the used gas (air at 25°C) has no large influence at the so calculated drag. Additional to that, I determined the zeroliftdrag (nearly the parasitic drag) and subtracted it from the general wingdrag to become a guess for the induced drag. My question: Why are the results for the induced drag so different for the different ways of calculation? Thank you very much! |
April 9, 2015, 17:29 |
Rep Power: 143 |
This approach appears to be very sensitive to the global imbalances. Try converging to tighter imbalances and see if that improves things.
April 10, 2015, 05:01 |
Rep Power: 11 |
Hi ghorrocks,
thx for your fast answer! I'm an absolute newcomer in cfd-practice. What do you mean with "converging to tighter imbalances". I have choosen a huge control volume sourrounding the wing (wingdept x 100 x100 x 800) and for first evaluations a rough unstructured grid. For better results I will refine the Mesh with Prism Layers around the wing. Is the formulation of my expression: "0.5*Density*areaInt((Velocity v)^2+(Velocity w)^2)@OUT" equal to the above shown formula? KV.jpg Wing.jpg |
April 12, 2015, 07:46 |
#4 | |
Rep Power: 143 |
And while you are at it, you transition very quickly from fine mesh on the wing to coarse mesh further away. This will also be a problem, especially if you are trying to pick up small differences in the momentum field. Have a look in the literature at the sort of meshed they use - you will find the transition is much gentler, and they usually have a tail of fine mesh in the wake region (which is where your momentum deficit will exist). |
Rectangular wing Induced drag | milind543 | SU2 Shape Design | 2 | August 19, 2013 13:18 |
Calculating Induced drag of a wing from Trefftz plane analysis in FLUENT | pratikkr | FLUENT | 0 | May 16, 2013 14:14 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | STAR-CCM+ | 3 | April 28, 2012 08:20 |
Negative Fuselage Drag on a Tandem Wing? | mmn1239 | Main CFD Forum | 1 | April 7, 2012 04:52 |
Isolating wing induced drag component | siw | CFX | 2 | June 22, 2010 10:21 |
