April 30, 2015, 02:18 |
CFX error in solving 2D problem
N B Khan
Rep Power: 12 |
Dear Friends
Can anyone help me in solvingCFX problem. I meshed the simple flow over cylinder (2D) and then tried to give boundary condition in "setup". But when i clicked on "setup",,it give error Application Error in CFX-Pre: ERROR There was a problem importing the mesh from the requested file. The importing process reported the following problem: Model "Model" does not have a valid mesh associated with it. Body B61 is an unsuppressed surface body that does not enclose a volume. Only 3D volume meshes can be imported. If your model contains valid bodies as well as surface bodies then suppress the surface bodies and remesh before continuing. ERROR: Failed to export model. Does this mean that CFX cant solve 2D problem? Please help me I am new in this area. |
April 30, 2015, 09:36 |
Edmund Singer P.E.
Rep Power: 20 |
No 2D.
Extrude the elements to small width. Put sym or cyclic BCs on side walls to mimic the 2D problem. |
April 30, 2015, 18:35 |
Rep Power: 143 |
May 8, 2015, 04:38 |
#4 | ||
N B Khan
Rep Power: 12 |
Last edited by wyldckat; May 8, 2015 at 15:25. Reason: merge consecutive posts, posted a few minutes apart |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
