How to initialize stratified temperature profile in a rectangular tank
Old   May 11, 2015, 20:13
Smile How to initialize stratified temperature profile in a rectangular tank
Mrityunjay sahu
moon1234 is on a distinguished road
I am working on destratification process in a tank.Air bubble plume is used to destratify.
My tank dimension is 1.44X1.44X1.12. I want to study this process by using k-e turbulence model. However, I wanted to initialize the domain with stratified non linear temperature profile through out the domain. Kindly advise me the procedure to initialize it.
Thank you in advance.
moon1234 is offline   Reply With Quote
Old   May 12, 2015, 06:49
Use a CEL expression or a 1D interpolation function to define the initial stratification profile as an initial condition.
Old   June 11, 2015, 14:47
munmun
MJ1234 is on a distinguished road
I am trying it for rectangular domain as well. I have tried to put it as CEL function. But it is showing dimension unmatched?
Could you suggest me an example?
MJ1234 is offline   Reply With Quote
Old   June 11, 2015, 18:41
CEL requires the units to be correct for it to be a valid expression. You obviously have not got the units correct. Post the CEL expression and we will have a look at it.
Old   June 11, 2015, 18:54
Mrityunjay sahu
The expression I want to put in is Temperature (T) = T*(1-tanh(2*(z-h)/h)
here h = depth of tank
z = varying depth
tanh(x) = exp(x)-exp(-x)/exp(x)+exp(-x)
I am getting following error
Bad expression value 'temperature' detected in parameter 'Buoyancy Reference Temperature' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/DOMAIN MODELS/BUOYANCY MODEL'.
CEL error:
The dimensions of the argument to function 'exp' are inconsistent with expected dimensions.
Argument dimensions resolve to 'm'; expected '<dimensionless>'.
Kindly help
Old   June 11, 2015, 20:09
Opaque will become famous soon enough
Could you please your CEL section as it stands in the software ?
If tanh(x) defined anywhere, or built-in ? or you simplified the expression for us.
I think you meant as follows
DimlessDepth = (z - h ) / h
  DimlessDepth =2*(z - h ) / h
  MyTempDist = MyTrefValue *(1 - (exp(MyDimlessDept)-exp(-Same))/(exp(Same)+exp(-Same))
In any case, the expression you are using will not work for the Buoyancy Reference Temperature since it MUST BE a single valued expression for the region. It cannot be a distribution since it will not be compatible with implementation as described in the documentation.
Opaque is offline   Reply With Quote
Old   June 18, 2015, 10:51
Mrityunjay sahu
Thanks for your guidance.
However, I could not get your question on "Could you please your CEL section as it stands in the software ?".
Yes I simplified tanh(x). It is not built in function.
However my query is im DimlessDepth "h" is variable and it changes. Shoud I use step function or any other function to define it?
Kindly guide me. Thank you in advance.
3d rectangular tank asdnet36 Structural Mechanics 0 January 25, 2014 12:24
Unsteady temperature profile rachana Fluent UDF and Scheme Programming 2 December 29, 2012 09:16
Fully developed temperature profile in OF !!! Goutam OpenFOAM Running, Solving & CFD 0 July 5, 2012 07:44
Temperature Profile through a fluid solid interface Studentdrak CFX 4 January 31, 2012 22:23
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 00:58
