return code 1_ segmentation violation_SID HANDLER |
May 12, 2015, 09:48 |
ambika dubey
Rep Power: 11 |
| ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Signal caught: Segmentation violation | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: SIG_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ please help me to solve this error. I am working on coal biomass co combustion in 210mw boiler furnace. |
May 12, 2015, 18:21 |
Rep Power: 143 |
Probably related to this FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
May 13, 2015, 03:20 |
segmentation violation, SIG hANDLER, Return code 1
ambika dubey
Rep Power: 11 |
Thanks sir... i will try but still i am unable to sort it off.
May 13, 2015, 05:49 |
Rep Power: 143 |
If you explain what you are doing and the circumstances by which the error came about we may be able to help you.
December 15, 2015, 06:37 |
Sig_handler
sandeep
Recently I have faced the similar/same issue
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Signal caught: Abnormal termination | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: SIG_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX partitioner exited with return code 1. | +--------------------------------------------------------------------+ But this error occurred during the partitioning. This is because the default MeTiS k-way algorithm in CFX cannot handle large models, if the number of elements exceeds about 80MM, then we will end up with this error. As a solution we can use the other partitioning algorithms: In the Partitioner tab check Use Large Problem Partitioner. This enables Optimized R.C.B. as Partitioning algorithm. We can also use Directional R.C.B or D.R.C.B. While using some clusters or super computers we can enter the following commands; -part-large by default invokes Optimized R.C.B., -part-mode drcb for Directional R.C.B. -part-mode rcb for R.C.B. |
ANSYS CFX solver exited with return code 2 | vmlxb6 | CFX | 6 | June 22, 2017 18:01 |
Solver: return code 9 | abdefk | CFX | 1 | May 5, 2014 19:04 |
CFX code 01 return error | Muhammadwaqas | CFX | 3 | May 1, 2014 09:13 |
Error in CFX Solver | Leuchte | CFX | 5 | November 6, 2010 06:12 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
