May 26, 2015, 19:02 |
Domain Imbalance and Conservation target
Rep Power: 11 |
Can somebody explain what is the significance of domaine imbalance for momentum equations ? I understand the significance for mass equation but not for the others ...
Also, in solver control, if ''conservation target'' is desabled, is the default value of the conservation target (0.01) still applied ? |
May 26, 2015, 20:41 |
Rep Power: 32 |
Let us see
Continuity equation = conservation of mass --> imbalance is a mass sink/source that has not been removed, or still left Mometum equation = conservation of linear momentum or force balance --> imbalance is a net force (sink/source) still left to be removed Energy equation = conservation of thermal/total energy --> imbalance is a net amount of energy (sink/source) still left to be removed species equation = .... Hope the above helps, |
May 26, 2015, 21:13 |
#3 | |
Rep Power: 11 |
Yes, I seem it's clear.
So, if I have a big imbalance in Y Momentum equation this means that the equilibrium of Y forces is not verified, am I right ? And what about my question about 'conservation target' option ? Quote:
May 27, 2015, 11:03 |
Mr CFD
Rep Power: 14 |
If ''conservation target'' is disabled then you're no longer using it as a convergence criteria.
When it is enabled you're telling the solver to stop the simulation when: - The minimum number of iterations has been achieved - And when the residuals have fallen to your value you want (usually 1E-4) - And when the global imbalances are less than 1% (0.01). If it is disabled you're telling the solver to stop the simulation when: - The minimum number of iterations has been achieved - And when the residuals have fallen to your value you want (usually 1E-4) |
Automated check for convergence | Chander | CFX | 3 | May 2, 2012 18:07 |
Mismatch between H-Energy and massFlowInt(Static Enthalpy) | Chander | CFX | 13 | December 16, 2011 11:37 |
convergence and conservation target of h-energy euqation | gitsnedbutzi | CFX | 3 | April 20, 2011 18:58 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Why P-Mass imbalance =+ - 1solution seems physical | Dai | CFX | 2 | September 29, 2006 08:21 |
