Rotating wind turbine - SAS SST
Old   July 9, 2015, 05:25
Default Rotating wind turbine - SAS SST
Florian
Flo27 is on a distinguished road
Hi guys,
I'm simulating a Darreius rotor combined with a Savonius rotor.
I made a unstructured mesh with a structured area at both sides of the rotating interface, so that the mesh at the interface matches perfectly each time step.
I ran the simulation for about 1000 time steps and noticed a serious problem at the transition from the structured area to the unstructured area in the rotating body. (See Picture)
My boundary conditions are:
Transient Simulation:
-Time steps: 2.5e-05s
Rotating:
-4000 rpm
Stationary:
-Velocity: x = 15 m/s
Advection Scheme:
-Central Difference (Bounded CDS)
Transient Scheme:
-Second Order Backward Euler
-Automatic Timestep Initialization
Turbulence Numerics:
-High Resolution
I really don't know whats wrong and I would be very happy if someone could help me.
Kind regards,
Flo27
Flo27 is offline   Reply With Quote
Old   July 9, 2015, 06:51
Why did you do that? How does that help? GGI interfaces are pretty good and should not produce any significant diffusion on a reasonable mesh. So matching mesh across the interface should be unnecessary.
What is the serious error? The ring of high velocity at the interface?
If so, try this:
* do you see it when you plot velocity (not velocity in stn frame)
* Check you are not plotting hybrid values
* do you see it when you use other differencing schemes such as Hi-res or hybrid?
* did you have an initial condition where the rotating bit was initialised with a rotating velocity (ie zero velocity)?
* Are you sure you have correctly put an interface between the rotating the stationary bits? what type of interface did you use anyway? I am suspicious you have not done this properly as matching nodes over interfaces is not usual procedure.
Wind turbine simulation Saturn CFX 60 July 17, 2024 05:45
Rotating Wind turbine rotor model step up shiyun CFX 3 November 6, 2017 10:34
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
