Boundary Conditions for a spherical far field/ easier way of setting up multiple sims |
August 21, 2015, 05:56 |
Rep Power: 13 |
Hi everybody,
I would like to simulate a wing enclosed in a sphere in ANSYS CFX. At the moment I set the boundary conditions by entering a primitive region which slices the sphere in a half. Then I assign one half to be an inlet and the other one to be an outlet. However, I need to run simulations fro several angle of attack. At the moment I rotate the sphere for every AoA and try to slice the primitive region at about the same position as for the previous setup. I think this not a very efficient way of doing it. I was wondering if there is an easier way of doing it and/or a more accurate way (because I doubt that I pick always the same position for the primitive regions). Also is the way of assigning the BC correct? Hope someone can help me out! Thank you very much in advance! |
August 21, 2015, 19:10 |
Rep Power: 143 |
When you start a new simulation it is a really good idea to first go to the library (or google these days) and see what other researchers have done. There are zillions of papers on this sort of stuff so you might as well find out what they used.
The "C" grid is a popular option. That has a curved inlet and a flat outlet. You can then change angle of attack easier. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Setting Temporal Boundary conditions in ANSYS CFX | avinash- | Main CFD Forum | 1 | November 22, 2011 06:53 |
