August 8, 2015, 07:06 |
Fatal overflow in linear solver
soumya nanda
Rep Power: 10 |
Hey guys
I need an help in 2 way FSI simulation. Actually i am trying to silmulate flow past a blunt body using 2 way FSI with CFX module of ANSYS. But i am not able to simulate it correctly. Every time i run cfx after some iteration it is showing fatal overflow in linear solver. The command window shows something like as shown below. //** ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 21 CPU SECONDS = 4.802E+02 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.00 | 3.5E-19 | 2.2E-17 | 4.6E+14 * | | V-Mom | 0.00 | 8.3E-20 | 5.7E-18 | 1.1E+14 * | | W-Mom | 0.00 | 8.7E-20 | 5.4E-18 | 1.1E+14 * | | P-Mass | 0.00 | 1.4E-34 | 5.7E-33 | 8.8 2.2E+14 * | +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ****** Notice ****** | | A wall has been placed at portion(s) of an OUTLET | | boundary condition (at 18.6% of the faces, 16.4% of the area) | | to prevent fluid from flowing into the domain. | | The boundary condition name is: outlet. | | The fluid name is: Fluid 1. | | If this situation persists, consider switching | | to an Opening type boundary condition instead. | +--------------------------------------------------------------------+ | H-Energy |62.19 | 1.4E-02 | 4.1E-01 | 5.8 4.0E-04 OK| +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory | | K:/Soumya/SAHOO_SIR_MODEL_2_WAY_FSI_0AOA_pending_tasks/dp0_CFX_So- | | lution-1/CFX_001: | | | | 1_full.trn, 0_full.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | ANSYS Solver terminated with return code 256 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS solver have been written to | | K:\Soumya\SAHOO_SIR_MODEL_2_WAY_FSI_0AOA_pending_t asks\dp0_CFX_So- | | lution-1\CFX_001.ansys | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | K:/Soumya/SAHOO_SIR_MODEL_2_WAY_FSI_0AOA_pending_tasks/dp0_CFX_So- | | lution-1/CFX_001: | | | | mon | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. **// I have tried by shifting the outlet by a large distance from the end of the blunt body. But it does not work. I can't also mention outlet as a opening because my outlet condition is supersonic. Please recomend me what to do???? Thanks in advance. Soumya |
August 8, 2015, 11:38 |
Davood
Rep Power: 10 |
Hi
By using the 1. SST turbulence method 2. Local time scale 3. high Mesh quality this problem will be solved probably. |
August 8, 2015, 21:36 |
Rep Power: 143 |
This question refers to 2 FAQs:
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F and http://www.cfd-online.com/Wiki/Ansys...f_an_OUTLET.22 |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 05:59 |
Fatal overflow in linear solver | alinik | CFX | 21 | February 29, 2016 16:43 |
fatal linear solver overflow | h.mortezaee | CFX | 2 | July 3, 2015 10:35 |
2D isothermal cylinder not converging | UPengineer | OpenFOAM Running, Solving & CFD | 7 | March 13, 2014 05:17 |
time consuming of the linear solver | luckycfd | OpenFOAM Programming & Development | 3 | September 23, 2013 05:29 |
