August 21, 2015, 06:00 |
Plot mesh deformation for transient case
beyonder
Rep Power: 10 |
I have been trying to track how the mesh is deforming with time in my transient case. It is finally creating some negative volume elements. Is there a way to animate the mesh deformation through CFD-Post? |
August 21, 2015, 06:14 |
Lance
Rep Power: 22 |
create a plane, display the mesh on that plane, animate?
August 21, 2015, 06:46 |
beyonder
Rep Power: 10 |
Thanks.
I tried and it worked. I was trying this since last week. I dont know what i was doing wrong. |
June 18, 2020, 12:52 |
Displaying the volume elements in CFX results
David
Rep Power: 12 |
Is there any way to display the volume elements in the CFX results (.trn files). My simulation comprises mesh deformation. I need to have a notion on how my volume elements are deforming throughout the simulation. Thanks! Mehdi |
June 18, 2020, 15:47 |
Gert-Jan
Rep Power: 27 |
In Post, you can plot a volume. This will plot the full 3D-elements.
There are several options plot a selection of elements. I hope the right option is there for you. |
June 18, 2020, 17:38 |
David
Rep Power: 12 |
Hi Gert-Jan,
Thanks for the reply. I am using V16. Is this an newly introduced option of CFD-Post? If it is not, may I ask you to let me know where should I search for this option? Thanks. |
June 18, 2020, 18:32 |
Gert-Jan
Rep Power: 27 |
I don't know if it present or absent in v16. I don't have all old versions installed.
If present, you should look for it in the top ribbon and select Insert>Location>Volume |
June 18, 2020, 20:26 |
David
Rep Power: 12 |
100% helpful! Thanks a lot.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Mesh deformation, negative volume! | Turbomachine | CFX | 12 | June 9, 2011 08:05 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
