September 10, 2015, 05:20 |
problem in concept of y plus?
Hydreaulic structures
Rep Power: 14 |
hi to all
i read help of cfx about near wall modeling, As it was written, two way exist for modeling flow near the wall: 1-wall function approach that using of scalable wall function that used for all models based on epsilon equation. 2- The Low-Reynolds-Number method that is suitable for models based on omega equation, in fact it has automatic near wall treatment in order to reduce Requirements of resolution. whether yplus for models are based on epsilon equation cant located in viscous sublayer? whether it induce To need to yplus< 0.2 in low reynolds number? unfortunately i dont find specific values for yplus for variety of turbulence models and only discussed about low-Reynolds number k-epsilon & k-w in help cfx, i find your mentions about this in previous topic as following: SST can handle any y+. k-e should be >11 k-omega should be <1 RSM should be >11 if using wall functions or anything if automatic. The question that came to me is that: as your mentioned , sst can handle with any yplus, in my simulation y+ value is too large, But I did was sensitivity study in mesh, whether really amount does not matter and What is the reason it? There is no specific limit? my impression is that it Due to the use of automatic near wall treatment. i opologize for long discussion thanks a lot for any comment kind regards hamid |
September 10, 2015, 06:09 |
#2 | |
Rep Power: 143 |
The maximum value allowable for y+ comes down to a mesh size sensitivity, and the error you are happy to have in the simulation. |
September 11, 2015, 03:04 |
Rep Power: 14 |
hi dear glenn
as your mentioned, your guess about my question is correct and I mean it was. thanks a lot |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
Mixture model problem - could someone please advise? | matlab_monkey | FLUENT | 2 | July 26, 2012 08:20 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
