Problem Execution Control ICEM-CFX
Old   September 9, 2015, 14:43
Default Problem Execution Control ICEM-CFX
Hebert Cote
cote2714 is on a distinguished road
I have this problem with Execution Control in the cfx.pre
when I have to work with multiple configurations. I have to create my input file (.mdef) but I have this warning message and then got the following error.
any help is welcome. Thaks
The Solver Input File value will be ignored when the solver is started as CFX-Pre is within Workbench.
Remesh Object: Remesh 1
Activated by condition: Interrupt Condition 1
Executing remesh command:
/software/ansys/v140/icemcfd/linux64_amd/bin/icemcfd -batch
-script
/software/ansys/v140/CFX/etc/Remeshing/icemcfd_Remesh.rpl
CFX Solver Results generated before remeshing have been written to:
/home/arrabiye/Ansys/MMesh3/Results/NMMesh_04_014/6_oldmesh.res
Text output generated during remeshing has been written to:
/home/arrabiye/Ansys/MMesh3/Results/NMMesh_04_014/6_remesh.out
| An error has occurred in cfx5solve: |
| ANSYS CFX Solver Input File does not exist |
| The following user files have been saved in the directory |
| /home/arrabiye/Ansys/MMesh3/Results/NMMesh_04_014: |
| cfx5mondata.out, cfxpre_engine_error.log, 6_remesh.out, |
| 6_oldmesh.res |
This run of the ANSYS CFX Solver has finished.
cote2714 is offline   Reply With Quote
Old   September 10, 2015, 02:21
Lance
Lance is on a distinguished road
-script
Im guessing the remesh failed and did not generate a new file. What does it say in 6_remesh.out?
Lance is offline   Reply With Quote
Old   September 10, 2015, 08:22
Default correction.
Hebert Cote
Sorry, post the error was not. This gives me the error actually.
| Remeshing |
Activated by condition: Condicion 1
C:\Program Files\ANSYS
Inc\v150\icemcfd\win64_amd\bin\icemcfd.bat -batch -script
Inc\v150\CFX\etc\Remeshing\icemcfd_Remesh.rpl
D:\Simulaciones
Tesistas\PIG\Caja-Tubo\ICEM-CFX\ICEM-CFX_files\dp0\CFX-1\CFX\C-
FX_001\Configuration1_001\141_oldmesh.res
D:\Simulaciones
FX_001\Configuration1_001\141_remesh.out
| Unable to retrieve 141_remesh.out from working directory: Cannot |
| move to D:\Simulaciones |
| Tesistas\PIG\Caja-Tubo\ICEM-CFX\ICEM-CFX_files\dp0\CFX-1\CFX\CFX_- |
| 001\Configuration1_001\141_remesh.out: Permission denied |
| Warning! |
| An error has occurred during creation of a directory for |
| additional output files. To avoid losing results, the working |
| directory D:\Simulaciones |
| 001\Configuration1_001.dir will be kept at the end of the run. |
| Please tidy this directory up yourself when you have extracted |
| what you need from it. |
| D:\Simulaciones |
| 001\Configuration1_001: |
| 141_newmesh_01.mesh.log, cfx5mondata.out, cfxpre_engine_error.log, |
| temp.fbc, temp.fbc_old, 141_remesh.out, 141_oldmesh.res |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
Old   September 10, 2015, 08:58
Lance
D:\Simulaciones
Seems like workbench isnt doing what it is supposed to do. Is there a file called 141_remesh.out in that directory? Anyway, have you tried to run cfx stand-alone instead? Is it write-protected?
I never understood the benefit of using workbench...
Old   September 10, 2015, 11:12
Hebert Cote
the file is there in that directory. and not protected.
when active control of execution, sends me this message.
Old   September 10, 2015, 13:03
Hebert Cote
Can i send my project?
execution control., icem-cfx, remeshing
[ICEM] Grids problem in CFX (imported from ICEM) Anna Tian ANSYS Meshing & Geometry 0 July 9, 2015 22:13
Grids problem in CFX (imported from ICEM) Anna Tian CFX 10 July 9, 2015 09:44
[ICEM] Problem with export mesh icem to CFX TallesC ANSYS Meshing & Geometry 6 February 6, 2013 09:56
[ICEM] Problem with export mesh icem to CFX TallesC ANSYS Meshing & Geometry 2 January 24, 2013 15:41
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
