how to increase cores number when we use CFX and ansys solvers
Old   May 20, 2015, 10:07
Default how to increase cores number when we use CFX and ansys solvers
wanglingjun
WANGFIRE is on a distinguished road
hi every one !
in two- way fsi use cfx and ansys by .inp file. how to increase cores ansys solver in paralel environment .
as follows :*** NOTE *** CP = 4.056 TIME= 11:34:39
No input port number for master code; an available port will be
obtained for socket connection and it will be saved to: ANSYS.port.
Port number = 51382
Master Socket number = 1
Number of codes = 2
Slave ID: 2; Socket number = 2
FIRST SYNCHRONIZATION POINT OF MASTER CODE:
GET CODE INFORMATION FROM SLAVE CODES
ANSYS solver only use two cores .
Total number of cores available : 8
Number of physical cores available : 8
Number of cores requested : 2 (Shared Memory Parallel)
so i want to increase cores in ANSYS SOLVER .
I need everyone' help.
thank you !
WANGFIRE is offline   Reply With Quote
Old   June 2, 2015, 15:52
stumpy is on a distinguished road
The command that launches the ANSYS solver needs to include:
-np 4
for example (to solve on 4 cores). If you are starting from the CFX Solver Manager then you can type the above into the "ANSYS Arguments" field.
stumpy is offline   Reply With Quote
Old   September 30, 2015, 08:56
Default cfx and ansys multi cores
wanglingjun
stumpy
i am grate for your help!
thank you very much
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 16:32
Nusselt Number calculation in Ansys CFX azurespirit CFX 36 December 3, 2016 19:29
Specify number of cores that CFX should use. Lance CFX 16 July 20, 2016 09:04
error about fsi in CFX and ANSYS WANGFIRE CFX 1 April 21, 2015 01:48
Turbulent Schmidt Number in Ansys CFX 12.1 DiddyPablo CFX 7 May 23, 2011 11:20
