Compressible amosphere using opening
Old   October 15, 2015, 13:52
Default Compressible amosphere using opening
Dino9111 is on a distinguished road
Hi together,
I would like to simulate just a area (box with dx=50m x dy=50m x dz=25m) with compressible air using opening boundary at the sides and a wall at the bottom. Intention is to create a realistic atmosphere with a negative temperature gradient with increasing height without any flow (or almost).
Initial and boundary condition for temperature: T(y)=288K-(0.976 K/100m)*y
(using adiabatic temperature gradient of atmosphere g_ad)
ref. pressure: 1 atm at (0,0,0)
If I set "relative pressure" at "opening pressure and drn." at 0 Pa, I always get a flow downwards at the center of the box (when compressibility and byouyancy is enabled - I need both effects in later simulations).
I'm not sure but as far as I understood the doc, I should define hydrostatic pressure p(y) at my opening boundaries.
--> Initial and boundary condition for pressure: p(y)-pref with
p(y)=p0*(1-(g_ad*y/T0)^(M_air*g/(R*g_ad)) (barometric formula; p0,T0 at y=0)
But then, in the center there is a flow upwards.
Has anyone an idea how to set boundary conditions etc. correctly?
Thanks a lot in advance!
Dino9111 is offline   Reply With Quote
Old   October 16, 2015, 06:22
Erik
evcelica is on a distinguished road
Translational periodic conditions might be suitable here.
evcelica is offline   Reply With Quote
Old   October 20, 2015, 05:17
Hi evcelica,
first of all thanks - it works qute well. But unfortunately then I can't define a wind profile at the sides (for later siimulations).
Isn't there any possibility to define relative pressure at an opening correctly (so that there is no flow initiated by pressure differences)?
And why doesn't relative pressure = 0 not work? No pressure difference-->no flow?!
Old   October 21, 2015, 07:15
OK i finally solved it...
for those who are interested:
You have to define for the realtive pressure at the opening boundary: p(y) - pref + density*g*y because p(y) is the absolute pressure, but the pressure you have to define at the opening boundary is interpreted to be without the hydrostatic part.
compressible gas, hydrostatic pressure, opening boundary
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
Opening boundary condition for multiphase analysis in CFX shivasluzz CFX 3 May 15, 2015 09:49
How does CFX treat an opening when heat transfer is modelled? JuPa CFX 2 September 9, 2014 05:34
How to properly set up an opening in buoyancy driven problems lavoz CFX 5 July 23, 2014 06:06
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 16:51
