How to write Expression for Transient study
Like Tree3Likes
  • 1 Post By tomson199
  • 1 Post By Lance
  • 1 Post By brunoc
Old   December 1, 2015, 01:02
Post How to write Expression for Transient study
AK5
AK5 is on a distinguished road
Hi guys,
I want to know how to write expression for a body whose temperature will vary from 0 C at 0 sec to 120 C at 10e-6 sec and remains constant at 120 C till 1 sec.
Best Regards
Thankyou In Advance
AK5 is offline   Reply With Quote
Old   December 1, 2015, 03:32
Thomas
tomson199 is on a distinguished road
If your simulation will be last 1 sec, the formula is:
if(t<=10e-6 [s], 0 [C], 120 [C])
AK5 likes this.
tomson199 is offline   Reply With Quote
Old   December 1, 2015, 04:26
AK5
Thanks for the reply
I make this as an expression and put this expression in the body, will the temperature remain constant at 120C after 10e-6 sec up to say 1,2..10sec.
Thankyou In Advance
Old   December 1, 2015, 04:46
Thomas
You would like drop temperature to 0 C after 1 sec?
Old   December 1, 2015, 06:48
AK5
thanks for your reply
at 0 sec it should be 0 C
then at 10e-6 it should be 120 C
and after that the temperature should remain constant at 120 C till 10 sec
i tried to put the above equation in an expression (t<=10e-6 [s], 0 [C], 120 [C]). It is showing error.
Thankyou in Advance
Old   December 1, 2015, 07:51
Lance
Lance is on a distinguished road
CEL is pretty powerful and you should spend some time learning the syntax. Here's probably what you want:
if(t<10e-6[s],mod(t,10e-6[s])/10e-6[s]*120[C],120[C])
(It will remain at 120 [C] after 10e-5 seconds)
But be aware that the mod function is a bit buggy when using decimal numbers.
AK5 likes this.
Lance is offline   Reply With Quote
Old   December 1, 2015, 07:58
AK5
Can you recommend something i want learn this CEL, so that i can write more complex equations.
thankyou so much
Old   December 1, 2015, 08:22
Lance
The manual is a good start... There are some CEL examples in the tutorials too.
Old   December 1, 2015, 09:21
AK5
Thankyou
I'll see what i can find about the manual in the internet and get back to you..
Old   December 2, 2015, 14:14
Bruno
brunoc is on a distinguished road
You can't directly fix the temperature of a domain in CFX. What you can do instead is use a big enough energy sink/source so that the temperature in each control volume remains really close to your intended temperature. Something like:
C (T_{ref} - T)
where C is the big enough constant [W/(m^3 K)] and T_{ref} the temperature you want.
AK5 likes this.
brunoc is offline   Reply With Quote
How to write an expression in CFD-POST? siamak1438 CFX 2 August 28, 2015 03:00
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 16:47
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
expression for rotatin a disk hmasenger CFX 3 April 8, 2013 18:24
write an expression Cecco CFX 3 June 19, 2012 16:59
