January 4, 2016, 10:09 |
Node number CFX
Jiri
Analysis of the rotating machine consists of a few domains connected via stage interfaces.
I need to export pressure on selected surface (blade) and use it further. If I do the export in CFX Post I receive .csv file including a set of values x,y,z, pressure and node number. However, the node numbers always begin with 0, 1, 2 etc. Obviously these are not node numbers created during meshing. These are node numbers assigned by CFX Post. According to what the .csv file is generated (sorted) when exporting the variables? Because it is not sorted neither according to x nor y nor z nor pressure. Thanks for any help |
January 4, 2016, 11:27 |
Rep Power: 32 |
Correct, you are getting the local numbering on the location being exported.
Did you check if the global node number can be exported as an additional column ? Check in the Geometric variables list. |
January 5, 2016, 07:40 |
Jiri
No there is not such possibility.
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
