Volume fraction correction exponent / Grace Model |
October 2, 2013, 10:10 |
Mathieu
Rep Power: 12 |
Hi guys,
I have a simulation of multiphase flow (Water flow in a conduct with air injection by a hydrofoil place in the middle) and I use the grace drag model. I inject 1mm bubbles diameter. I notice that the volume fraction correction exponent have influence on my solution (Crash or not ). I read the help menu in Ansys for this correction exponent but not give enough info...For small bubble use a value of -1, and larger bubble a value of 4...I did a little search on the net for more info but i didn't have succes, has anyone have some infos, links to give me about that? Thank you Math |
August 21, 2018, 05:02 |
Gert-Jan
Rep Power: 27 |
I would like to raise this question again.
Mathieu, did you (or someone else) find anything on this topic? I am desperately looking for it. |
correction exponent, grace, multiphase flow, volume fraction |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Difference between Volume Fraction and Mass Fraction in CEL | foo7 | CFX | 0 | September 21, 2011 08:45 |
