January 8, 2016, 12:01 |
Fluctuating components on CFD-post
Marchetto
Hello, i'm new in this forum
I would like to ask you a question. I need to know how to calculate the fluctuating components of trasversal and streamwise velocity in my BSL-RSM simulation in CFX. The problem is a flow past a rectangular cylinder. In particular I want to extract the values of u' and v' on a plane downstream the cylinder. In attached the picture of my problem. thank you so much |
January 10, 2016, 01:23 |
Rep Power: 143 |
You can get u' from the Reynolds stresses. Or are you asking how to post process it? Just put a plane across the flow at the required location and you can use that plane to display variables or extract data.
January 10, 2016, 04:08 |
Marchetto
Thank you for the aswer. I created three planes in which calculate the u' v'. But, in particular, what is the function in tab espressions that i have to use? ......?.....(reynolds stress u)@plane
The same problem with the search of y plus around the square section : ......?.....(y+)@wallsection |
January 10, 2016, 16:56 |
Rep Power: 143 |
You will have to define your own variable to calculate it. It is not a variable in CFX by default.
y+ only exists at the walls. If your plane goes through the middle of the domain there will be no value for it in the middle of the flow and it will only exist at the walls. |
Problem in CFD -post | pratikvn | ANSYS | 4 | March 21, 2018 02:56 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
View results at a contact region in CFD post | AGP | FLUENT | 0 | June 10, 2014 11:11 |
CFD Post velocity initialization | vitulaaak | CFX | 0 | November 22, 2012 06:45 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
