axial flow compressor influence on fluid at inlet
Old   February 1, 2016, 05:35
Default axial flow compressor influence on fluid at inlet
Rohit S Iyer
rohit_turbo is on a distinguished road
I am working on a transonic axial compressor project in CFX, but I need help on a particular note which I am not sure off.
Can anybody please explain upto what length upstream of the rotor should I be taking as rotating domain since i am not sure till what axial distance does the compressor influence the fluid at inlet ??
If at all anybody would enlighten me on this it would be really helpful!
Thanks,
Rohit
rohit_turbo is offline   Reply With Quote
Old   February 1, 2016, 22:25
D.B
DB
D.B is on a distinguished road
Thanks,
Rohit
Can you explain , what your domain is? Since it is a transonic compressor, I would assume that it is either in a rig or a gas turbine engine. Also I am assuming that you have no guide vanes/stators upstream of the compressor since you haven't mentioned that explicitly. So in that case you should only have a rotating domain atleast upstream of the compressor. In that case it would be ideal to do a domain independence study. You can start with C or 2C distance upstream of the compressor, with C being the maximum chord length.
-D.B
D.B is offline   Reply With Quote
Old   February 2, 2016, 00:16
Rohit S Iyer
Dear D.B,
Thanks for your reply.
My domain is a single stage transonic compressor.
yes you are exactly right, no IGVs have been taken into consideration upstream of the rotor and yes it is a test rig. I have tried doing a study in which I have taken 2C length.
A domain upstream rotor with 2C length rotating and non-rotating comparison I have done.
But, a doubt arose in my mind that whatever may be the case If I keep the inlet domain at 2C rotating, the fluid undergoes a pre-whirl and then enters the compressor rotor. I thought there might be a thumb rule or so to keep a particular distance upstream of the rotor.I should try a different distance as u say and try giving it a rotation. May be I can establish something on this!!.
Thank you
Old   February 2, 2016, 10:05
Take a far upstream ahead of the rotor like 2C or 3C, 4C ..., but you can set a rotating hub wall in the Pre which will be the same as your real machine. The rest will be set as a non-rotating hub.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Multiphase Flow BC-Mass Flow inlet not available? yimingchen.ok@gmail.com Siemens 1 July 18, 2014 06:08
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
