error befor stast runing
Old   February 17, 2016, 01:21
Default error befor stast runing
yaseen
yaseen wsu is on a distinguished road
hello every one
before start any iteration, my running model stop and shows error??
as show in image
http://www.cfd-online.com/Forums/att...1&d=1455690029
yaseen wsu is offline   Reply With Quote
Old   February 17, 2016, 05:41
There is a problem with your CCL. You need to fix that, or if you cannot find it you should load it in CFX-Pre again and check the setup. You have missed something - but the error message gives no clues as to what the missing thing is unfortunately.
Old   February 17, 2016, 05:50
yaseen
dear Glenn Horrocks, I re loaded not one time, more than five time and reduced mesh density increase memory partition but the error msg. repeated this time I will begin from the first point I hope to be run.
Old   February 17, 2016, 06:11
If you have redone it through CFX-Pre then you need to start from a simple model and add your bits and pieces one at a time and see when it stops working.
Batch Job Runing under Linux Environment ck5285 FLOW-3D 9 April 28, 2009 20:47
Runing a simulation shuo Main CFD Forum 0 February 15, 2008 16:43
runing Fluent with a 64bit machine Rucy FLUENT 1 November 17, 2005 08:51
Runing Out of memory in Gambit Akin FLUENT 6 February 10, 2005 15:32
runing FLUENT on celeron CPU? Howell FLUENT 6 April 2, 2002 04:14
