Problem with interface between rotating and static domain
Old   March 2, 2016, 16:30
Exclamation Problem with interface between rotating and static domain
Mathieu
Math13570 is on a distinguished road
Hi guys,
I'm trying to simulate an hydrokinetic turbine, so I split my domain with a rotating and static domain. My problem is the connection between theses two interfaces...I you take a look at the streamline, the vortex downstream the turbine just stop immediately at the end of my rotating domain and begins before the blades! I could use some help here..
In CFX-Pre, my interface setting for interface models are :
option : general connection
Frame change : Frozen rotor
Thank you for your help!
Math13570 is offline   Reply With Quote
Old   March 3, 2016, 20:40
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Do you use the sliding mesh technique?
Ahmed Saeed Mansour is offline   Reply With Quote
Old   March 4, 2016, 05:55
Is your simulation converged? Have you run it long enough to convect the flow to the outlet? This is exactly what happens if you have not run it long enough.
Old   March 4, 2016, 20:05
turbo is on a distinguished road
Originally Posted by Math13570 View Post
Hi guys,
What you called "vortex" is the relative streamlines that will be ONLY seen in the rotating frame of reference domain. What is wrong with those pics? They look normal.
turbo is offline   Reply With Quote
interface, mesh connection, rotating domain
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
