Can't Display The Solver Monitor
Old   March 2, 2016, 13:16
Default Can't Display The Solver Monitor
claudy.daniel is on a distinguished road
I've just installed ANSYS 16 replacing the older version in Windows 7. I tried to solve a simple case in CFX. After I clicked Solution tab, I could still define run and start run. But, It didn't display the solver monitor. I could see a preview showing the contents of the application window when I hovered over in the application in taskbar.
In a few minutes, It showed that the solver run finished normally and I could see the good result.
Does anyone know what happened with my ANSYS? How to solve that issue?
claudy.daniel is offline   Reply With Quote
Old   March 3, 2016, 04:17
Maxim
-Maxim- is on a distinguished road
Sounds like a windows problem I think. Did you connect a second display or something so that the solver monitor is on another desktop? Or did you move the solver monitor window "off" your desktop (visible screen space)?
-Maxim- is offline   Reply With Quote
Old   March 3, 2016, 13:05
Thank you for your respond -Maxim-
No, i didn't connect anything or move the solver monitor window.
Anyway, I have re-installed ANSYS, but it's still showing the same.
Old   March 4, 2016, 02:00
Maxim
mmh that sounds strange. What happens when you right-click on the solution field "Display Monitors"?
Other than that I am out of ideas. Maybe this is a case for Ansys support?
Old   March 4, 2016, 09:11
When I encountered the issue, I wasn't allowed to click "Display Monitors" which is shown with grey text.
But, I've just solved the issue and it's sound more weird. I tried again to hovered over solver monitor tab in taskbar and I right-clicked maximixe. Then, the monitor is shown. Now, I can even show the monitor by right-clicking the solution field "Display Monitors". I think I haven't done anything significant to the app or the computer.
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
convergence issues on steady state solver icemaniac178 CFX 1 March 30, 2011 19:11
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
how to monitor momentom coef in solver romance CFX 0 February 1, 2007 08:24
