Error occurs when I set the Opening Temperature using an expression |
April 1, 2016, 02:48 |
Tony
Rep Power: 10 |
Hi, everyone,
I chose "Opening" as boundary type of the outlet of a compressor diffuser. For the section of "Heat Transfer", I chose "Opening Temperature" and want it to change with Mach number and pressure at the outlet. So I fill an expression in the blank of "Opening Temperature".(see option.jpg) The expression named tTotalNext is shown below (see expression.jpg): (massFlowAve(Total Temperature )@Diffuser Outlet)*(pOutNext /(massFlowAve(Total Pressure )@Diffuser Outlet))^(2/7) Then an error immediately occurs after starting the run (see error.jpg). A paragraph in the report: Error processing expression 'Opening Temperature'. The expression is invalid because: Mach Number is not available for use in this term Total Pressure is not available for use in this term Total Temperature is not available for use in this term mOld is not available for use in this term pOld is not available for use in this term Error processing expression: Opening Temperature = tTotalNext +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Z:\Program Files (x86)\ANSYS | | Inc\v161\CFX\bin\winnt-amd64\ccl2flow.exe was interrupted by | | signal QUIT (3) | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. It looks like CFX cannot get Mach number, Total Pressure etc. to calculate this expression. But the initial solution must already have those info. I just start learning CFX. Why this error happens and can anyone tell me other ways to set opening temperature as an equation? Thanks in advance. |
April 1, 2016, 05:06 |
Rep Power: 14 |
Hmm
not sure if it helps, but I think I had a similar problem. Wanted to use "Absolute Pressure" and the solver crashed saying the variable is not available. Speaking with the support revealed I had to use "p" instead of "Absolute Pressure". A List of variables available is to be found in the reference guide of the documentation. There you will find for example that "Total Temperature" is represented by a variable named "Ttot" Chapter is named "Variables in Ansys CFX". Chapter number seems to be different depending on the Ansys Version. In Ansys 17 it is Chapter 16 of the Reference Guide. Maybe this might help. |
April 1, 2016, 05:45 |
Tony
Rep Power: 10 |
Thanks for your reply.
I substituted Total Temperature and Total Pressure with Ttot and ptot respectively. The solver crashed again. However, it's the first time I know Total Temperature can be written as Ttot. Thank you. Here is the message from report: Error processing expression 'Opening Temperature'. The expression is invalid because: Mach Number is not available for use in this term Ttot is not available for use in this term mOld is not available for use in this term pOld is not available for use in this term ptot is not available for use in this term |
April 1, 2016, 06:03 |
Tony
Rep Power: 10 |
I find a thread (http://www.cfd-online.com/Forums/cfx...ple-solve.html) suggesting to modify RULES file. I got that file in CFX/etc/. I looked for the descriptions about Relative Pressure, which must can be imposed by expression, and Opening Temperature.
PARAMETER: Relative Pressure Parameter Type = Real Quantity Type = Pressure Dependency List = ANY Profile Variables List = p,Pressure, ptot,Total Pressure, \ ptotstn,Total Pressure in Stn Frame Solver Name = PRES Dynamic Reread Item = Yes END PARAMETER: Opening Temperature Parameter Type = Real Solver Name = TTOT Quantity Type = Temperature Dependency List = XYZT,rNoDim,aitern,citern,atstep,ctstep, \ acplgstep,cstagger,T Profile Variables List = T, Temperature Lower Bound = 0 [K] Dynamic Reread Item = Yes END Now I don't know what is the proper way to modify the description of Opening Temperature. And can I update Opening Temperature by other ways like Fortran? |
April 1, 2016, 06:16 |
Tony
Rep Power: 10 |
I add ANY in the Denpendency List of Opening Temperature. Then it works. Is there any risk doing this? It seems to remove all the restrictions for Opening Temperature.
PARAMETER: Opening Temperature Parameter Type = Real Solver Name = TTOT Quantity Type = Temperature Dependency List = ANY,XYZT,rNoDim,aitern,citern,atstep,ctstep, \ acplgstep,cstagger,T Profile Variables List = T, Temperature Lower Bound = 0 [K] Dynamic Reread Item = Yes END |
April 1, 2016, 07:10 |
#6 | |
Rep Power: 143 |
Have you looked at the documentation monkey suggested? For instance it also says the name for Mach Number is "Mach". But there other restrictions as well - some variables are restricted by which variables they can be a function of. I think this is actually the problem you are seeing - you cannot make the total temp at an opening a function of the variables it lists. If you kludge the RULES file to allow you to do this you will just make the solver unstable and the run will crash.... that is why the restriction is there in the first place. |
April 1, 2016, 07:30 |
Tony
Rep Power: 10 |
Thank you, Glenn.
Yes, I had looked at the documentation. To make the trial simple, I just abbreviated total pressure and total temperature. ptot and toto still appeared in the message describing error. Yes, I agree with you that my modification makes the restriction too slack. In case of any bad results from the case after modifying RULES file, I am also conducting a case with a constant and educated-guess opening temperature on another computer meanwhile. |
boundary condition, compressor diffuser cfx, expression, opening temperature |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
set wall temperature | Reunion | STAR-CCM+ | 7 | January 29, 2012 06:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
