April 30, 2016, 06:54 |
pipe idealization ansys workbench
yonglin feng
Rep Power: 10 |
when i use the workbench, it show the problem.
"The program has detected a tubular cross section that contains a bend. Consider using a “pipe idealization” condition in order to capture possible cross section distortion" do you know how to solve it. thank you |
December 15, 2017, 12:03 |
I'm aware I'm late but I was looking for info on this right now so it might be helpful to someone else.
http://www.ansys-blog.com/ansys-pipe-simulation/ https://www.sharcnet.ca/Software/Ans...alization.html Basically, in Mechanical select your geometry that contains a pipe profile that has a bend in it. Under Model Type instead of Beam select Pipe and then in right click the Static Structural and Insert -> Pipe idealization. You can read about what Factor does in the 2nd link. \o/
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
Can't restart 2-way FSI using ANSYS 14.0 Workbench | MSHowes | ANSYS | 2 | July 3, 2014 13:30 |
Gambit vs. Ansys workbench mesh generating | sanlee39 | Main CFD Forum | 2 | April 8, 2013 06:09 |
ansys workbench on linux | zoe~~ | FLUENT | 7 | January 17, 2013 23:02 |
Ansys Workbench : Unable to update 3D Model | kh_thakor | ANSYS | 0 | January 22, 2011 04:34 |
