Interrupt Control for a expression-based monitor
Old   November 30, 2016, 14:06
Default Interrupt Control for a expression-based monitor
kohyar
kohyar is on a distinguished road
Hi every body
I am about to use interrupt control for an expression value which is locator-based, the expression is as below:
"areaAve(Total Pressure)@Stationary Outlet"
using the expression the area average of total pressure is calculated on outlet of domain. considering the name of this monitor point to be as ''m''. I want to interrupt the run when the standard deviation of m becomes lower than 100 pa.
I use the below logic expression in interrupt control:
probe(Expression Value.Standard Deviation)@m 50 <100
but this error pops up
"Bad expression value 'probe(Expression Value.Standard Deviation)@MP outletP 50' detected in parameter 'Logical Expression' in object '/FLOW:Flow Analysis 1/SOLVER CONTROL/INTERRUPT CONTROL/INTERRUPT CONDITION:Interrupt Condition 1'.
CEL error:
The following unrecognised names were referenced: Expression Value.Standard Deviation (on 'm 50'), m 50.
I will be grateful if someone help me out.
Regards
kohyar is offline   Reply With Quote
Old   December 1, 2016, 07:22
Antanas is on a distinguished road
Originally Posted by kohyar View Post
Hi every body
CEL error:
Regards
Here's answer:
Antanas is offline   Reply With Quote
Old   December 1, 2016, 08:53
Opaque will become famous soon enough
What version of ANSYS CFX are you using ?
Have you setup the monitor statistics for the monitor point you are probing ?
Opaque is offline   Reply With Quote
interrupt control
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
logical expression for cfx interrupt control wjy-c CFX 0 November 29, 2013 04:30
How to monitor a CEL expression Luca L CFX 2 September 24, 2012 21:55
code for control volume based finite element metho yang Main CFD Forum 0 October 18, 2004 03:39
control volume based finite element araz Main CFD Forum 1 November 15, 2003 17:50
