May 15, 2016, 03:39 |
problem with residual
yaseen
Rep Power: 10 |
Dear all
this is the second time I post this problem I simulate free surface flow (spillway) using RNG k-e model, at coarse mesh (500000) at 250 iteration reach (10-4) and converge but in fine mesh (2.5 million) it doesnot (10-4) even after 1200 iteration (mesh quality in fine mesh is better than coarse in terms of skewness orthogonal ..) is that related to time scale in coarse mesh I select auto but in fine auto does not work I use physical 0.03 sec. I add residual from backup in cfx pre but the it does not appear in variable list in CFX post. also depth of water from experiment and CFX has difference (1 cm)!!, I read (why my result is inaccurate) thanks for your help http://www.cfd-online.com/Forums/att...1&d=1463297661 http://www.cfd-online.com/Forums/att...1&d=1463297714 http://www.cfd-online.com/Forums/att...1&d=1463297758 http://www.cfd-online.com/Forums/att...1&d=1463297793 |
May 15, 2016, 06:06 |
Rep Power: 143 |
Free surface simulations often do not converge well steady state. This is because of small transient surface waves. As you refine the mesh this effect will get stronger.
Free surface flows therefore frequently need to be run transient, even when the flow is actually steady state. |
May 15, 2016, 11:21 |
#3 | |
yaseen
Rep Power: 10 |
So by monitoring value of interest in free surface like (mass flow rate, drag, shear stress ......) we can say we reach steady even the residuals does not reach. |
May 16, 2016, 01:31 |
Rep Power: 143 |
Yes, if the parameters of importance to you have converged then it might be that your convergence is too tight. Have a look at the FAQ for a discussion on this.
But I was saying that to get tight convergence on free surface simulations you often need to run transient. |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
