May 24, 2016, 23:01 |
Expression Quesitons
Bohong.Zhu
Rep Power: 10 |
Hey, Guys. anyone can solve my problem? Thanks.
In my model, there is a tank which is full of water,and the height of tank is h. I put some salt into the water. The distribution of salt is not uniform, so the concentrations of salt in the different heights(0-h) is also different. I want to use a equation in CFX source, and the equation is S=H*C. C is the mass fraction of salt, and I can use mf.salt to describe it. But how to describe the "H", H is the height from tank bottom to tank top. "H" is the integration process. Can I use the Expression to describe this H? |
May 25, 2016, 01:57 |
Rep Power: 143 |
If the bottom of the tank is at z=0, then H=z. Isn't that obvious?
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 13:31 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
