July 6, 2016, 12:57 |
Turbine Cooling with Point Sources
Hi All,
I have been using point sources to model some film cooling in an axial turbine. I had success setting this up and running it, my problem is that it takes a very long time to create all these points and populate the necessary data fields. We are talking about airfoils with anywhere between 50 - 200 individual cooling holes, so this can get quite cumbersome, especially if changes need to be made. I was wondering is there was some way to import this information from external text files or tables using some sort of journaling or scripting technique? Any advice is greatly appreciated. Thanks. -Sam |
July 6, 2016, 15:09 |
Rep Power: 32 |
It would be good to contact ANSYS support for advice on this application. There are multiple approaches for modeling cooling holes. Using sources there are two possible approaches: point sources, or boundary sources.
The numerical details between point sources, and boundary sources are significant enough to consider evaluating them separately. However, using boundary sources, you can use profile files (.csv) and the setup is more convenient. Hope the above helps, |
cooled turbine, point source |
Turbulent flow in Turbine Blade Cooling Passage. | avinashjagdale | Main CFD Forum | 0 | February 9, 2014 01:34 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 | pedrin84 | CFX | 3 | August 25, 2010 14:07 |
Turbulence model for turbine blade cooling | CFD Student | FLUENT | 0 | December 20, 2004 08:30 |
gas turbine combustor linear cooling holes- cfd | P.K.UDAYAKUMAR | FLUENT | 1 | December 13, 2002 02:08 |
