Workbench 16.0 - Memory Allocation Factor
Old   August 7, 2016, 14:08
Default Workbench 16.0 - Memory Allocation Factor
Wojciech
196235 is on a distinguished road
Hi there!
I am currently working on Ansys 16.0 Workbench with the student's license and I need to ask you something. Each time I am trying to start Solver with my project error occures:
Illegal data area length CDANAM = NCOMPT CDTYPE = INTR ISIZE = 0
CRESLT = SIZE
Current Directory : /INTERP/SOLUTION/DST/VX
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine MEMERR |
On some websites I've found that this problem is connecteed with my computer's allocated memory and I found info that to overcome this problem I have to adjust the memory configuration. In Ansys help viewer I found this information.
Memory Allocation Factor: Use this method to modify the memory allocation for the CFX-Solver step as a whole. For example, a value of 1.05 for Memory Allocation Factor increases memory allocation by 5% and a value of 1.1 increases memory allocation by 10%.
My main problem is that I can't find those options in Workbench 16.0. I've looked up the internet and there are only results for lower versions like 8.0, but they are not working with mine.
Can you please help me with this?
Thanks
196235 is offline   Reply With Quote
Old   August 8, 2016, 02:37
Maxim
-Maxim- is on a distinguished road
When you are in "Define Run" in Solver Manager before you start your calculation, you have to check "Show Advanced Controls". After that, you have more tabs available, e.g. "solver". You can change the "Memory Allocation Factor" here or select and edit "Detailed Memory Overrides"
-Maxim- is offline   Reply With Quote
Old   August 10, 2016, 11:45
Wojciech
Thank you very much for your help. Now I know where to find it and it helped me when I changed this setting, I still however can't see the big difference when changing from 1.0 to 2.0 for example, but fortunately it cancelled my error
Old   August 11, 2016, 02:05
Maxim
Thanks for the feedback. I don't know why CFX can't handle that alone ('take as much as you need from my physical RAM').
I usually use factors like "1.2x" (see the 'x') instead of '2.0' - read up on the difference in the documentation in case you're interested
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 22:24
Run-time memory allocation error aniseh CFX 1 November 19, 2014 04:32
Run-time memory allocation error akalopsis CFX 0 November 17, 2014 17:17
Help understanding Memory Allocation Factor Todd CFX 1 March 6, 2008 13:27
how to define memory allocation factor in unix steven CFX 1 October 25, 2005 10:26
