Flow analysis for a centrifugal pump
Old   February 6, 2008, 02:01
Default Flow analysis for a centrifugal pump
raj
Hi all,
I want to carry out the leakage flow analysis for a centfrifugal pump.
I have made few assumptions in carrying out modelling.
1. i have merged the distance between volute inlet &
impeller outlet
My aim is to capture the flow leakage near the impeller & volute region.
please suggest on how to carry out the analysis further.
Thanks in advance to all
Old   February 6, 2008, 08:29
Default Re: Flow analysis for a centrifugal pump
Joel Thakker
Hi Raj,
Would it be possible for you to send it across to me and I can take a look at it if you want?
As part of the CFX team ourselves, if needed and approved by yourself, we could set up the file for you or train you in doing such analysis.
Joel
Old   February 7, 2008, 06:21
Melvin
I'm doing the same analysis for a centrifugal blood pump but have been unsucessful in obtaining values which are close to the experiment. You can obtain some information about modelling this from 'Computational Fluid Dynamics Analysis of the Pediatric Tiny Centrifugal Blood Pump (TinyPump)'.
Hi Joel, is it possible for you to take a look at my simulation?
Old   September 30, 2016, 02:23
Smile
kastarkas
kastarkas is on a distinguished road
hi melvin,
its almost 8 years now, anyway...i have a problem with boundary conditions of the same case when using Fluent. Have you tried Fluent, can you help me ?
kastarkas is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 07:49
Pump flow analysis help nithyanand Siemens 2 February 9, 2005 03:21
centrifugal pump john Main CFD Forum 0 April 22, 2004 06:13
2D incompressible Navier-Stokes solver for diffuser analysis of centrifugal pump WANTED !!! LI, J Main CFD Forum 1 November 19, 2003 23:49
centrifugal pump cfd analysis shatruhan lal FLUENT 1 November 6, 2003 06:23
