October 5, 2016, 00:21 |
Finding velocity at exact location
Syazwan
Hi everyone. I had a problem on my research and I need a help on it. I have done my simulation process and I want to know if there any ways to get the velocity on the exact location of my simulation. I have attached a photo to show my simulation result and I want to get the value of velocity at the red circle region. Thank you
October 5, 2016, 04:35 |
Rep Power: 14 |
You can postprocess your results at a specific location in several ways:
1. draw the velocity profile on the surface of the interface or boundary (if it exists) 2. With "Insert->Location->Plane" you can place a pane at the position desired and draw on i the velocity profile or even calculate the average value over the plane 3. If you need the Velocity at one point just "Insert->Location->Point" and draw the velocity or use the "Tools->Probe" functionality of cfx post |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Determine the exact location of the vertex center? | Anna | Main CFD Forum | 3 | April 4, 2006 11:04 |
