Finding Cells that have temperature and pressure less than a certain value
Old   October 5, 2016, 08:40
Default Finding Cells that have temperature and pressure less than a certain value
Lauren Blanchette
lablan is on a distinguished road
Hello All,
I am running case in which I am using a Metastable thermodynamic property table to enable the fluid to go past the fluid's saturation line. I want to now define an isosurface or some kind of function in order to determine which areas within the CFD domain are going past this line. Does anyone know of a way to use a table of values (such as the saturation line in this case) to set a criteria that highlights any cells that are below the saturation temperature for a certain Pressure?
I know that isosurfaces are very useful to find one value of one variable but I am unsure if it is possible to have two variables as the criteria and instead of one value of the variable, set criteria to highlight anything below one value?
Thanks!!
Lauren
lablan is offline   Reply With Quote
Old   October 5, 2016, 08:45
monkey1 is on a distinguished road
When you go to "Insert->Location->Volume" in CFX-Post and then select "Isovolume", you can define, that cells above, below or between specified values are drawn.
But you will only be able to this for 1 Variable. If you need 2 Variables maybe you will have to look for 2 Isolvolumes, define a spcific color for each of them and set a transparency, so that you would see cells with overlap of both values....
Or you can define that all cells for a certain temperature window are shown by the isolvolume and the color of the cells/isovolume will be selected due to the coloring variable pressure...instead of giving a fixe colour to the isovolume. in that way you could somehow print 2 variables with one type of visualisation
monkey1 is offline   Reply With Quote
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 04:56
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
