December 2, 2016, 06:50 |
Verify whether Infiniband is used or not
Chris
Rep Power: 9 |
Hi everybody,
I just set up Ansys 17.2 on a HPC cluster and except for some smaller issues it seems to work. I started 2 test simulations which I know would run with Intel MPI Distributed Parallel and Platform MPI Distributed Parallel. Since I have an Infiniband Connection between the nodes I certainly want to use it instead of the ethernet connection. So i questioned myself if there is any way to find out whether the Infiniband or the ethernet connection is currently used by CFX. Does anybody know a way? I would appreciate any help. Thanks and have a nice weekend guys. |
December 2, 2016, 14:24 |
Erik
Rep Power: 23 |
In windows I Look in task manager >> networking and see if the Ethernet connection has traffic. If the The infiniband network shows traffic, it is using TCPoIB, which you don't want either. I don't see any traffic at all when infiniband is working correctly.
December 3, 2016, 03:42 |
Chris
Rep Power: 9 |
I see, thank you.
It's a Linux cluster but I guess the cluster management system will do the same job. I'll have a look at it. Thank you for your advice. |
How to verify the solutions(e.g. flow.dat)? | Emily1412 | SU2 | 3 | April 10, 2014 12:06 |
How to verify a model's isotropy? | zhulianhua | Main CFD Forum | 0 | March 11, 2014 07:39 |
How do you verify CFD data, if no significant data to compare with can be found? | rgd | Main CFD Forum | 0 | March 10, 2013 08:50 |
A flow to verify a SGS model | crwan | Main CFD Forum | 6 | June 19, 2012 15:36 |
how to verify that turbulence has been established | MP | Siemens | 0 | March 16, 2005 10:31 |
