supersonic flow in vane channel
Like Tree2Likes
  • 1 Post By ghorrocks
  • 1 Post By turbo
Old   February 11, 2017, 07:08
Default supersonic flow in vane channel
Alex
Red Ember is on a distinguished road
Hi to all
Can anybody tell me what does mean the supersonic flow that I got in my axial compressor simulation? Is this effect a sign of something?
It's strange that it took place in stationary domain.
Velocity increases rapidly and then drops, static pressure drops and then rapidly increases, while total pressure increases smoothly as it should.
The solution convergence is good, grid is fine.
The worst (and the simplest) guess - wrong vane geometry, it won't be easy to check angles since I have only parasolid model and no draws.
But if not - may be there's any trick to abide this step? May be to change any air parameters for some time steps and then return to previous values?
Thank in advance
Red Ember is offline   Reply With Quote
Old   February 11, 2017, 17:17
Is this a region where the flow goes supersonic then returns sonic again? If so it does not sound like a device running at high efficiency to me (if efficiency is what you are looking for).
ghorrocks is online now   Reply With Quote
Old   February 12, 2017, 04:34
Alex
Yes, it returns to subsonic flow within stationary domain. And yes again, efficiency and massflow values are relatively low. But anyway, flow pattern is not normal even for low mode, am I right?
Old   February 12, 2017, 05:00
I am no turbomachinery expert but if your design is doing that in flow regime where the device should be operating well - then I suggest the stator design is not very good. I suspect it is choking in the gaps between stator blades.
So it is not normal for well designed turbomachines, but for a poorly operating turbomachine it is an example of one type of problem you can face.
Red Ember likes this.
Old   February 13, 2017, 08:41
turbo is on a distinguished road
If your solution is right, the velocity contour obviously shows a shock wave in the stator.
turbo is offline   Reply With Quote
Old   February 13, 2017, 08:58
Alex
Glenn and Turbo,
thanks for your answers. I think this compressor just suffers from choking at mass flow rate about 3/5 of expected value. I think here's problem with geometry indeed... But can you tell me what stage I should check firstly? The place where shock wave was generated, or upstream?
Old   February 13, 2017, 09:32
Reduce the stator vane count.
Old   February 13, 2017, 11:40
Alex
Oh, you mean to reduce number of vanes to increase the area between vanes that will lead to velocity decrease. I'll try it. But may be something is wrong with angles?
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
reverse flow occur while activating open channel flow boundary? mariam.sara Fluent Multiphase 7 April 26, 2015 07:24
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
Flow in Supersonic MHD Channel Antanas CFX 6 February 13, 2012 14:49
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
