May 5, 2012, 01:59 |
Simulation of gear pump in CFX
Stefan
Rep Power: 14 |
Hello,everyone,is there anybody who simulated the inner flow distribution of gear pump before? I have done an example as shown below
1,However, should the outlet be set as "opening"or "outlet" type? 2,if there is a small gap between outside circle of gears and the boundary fluid,what should be done?In the ICEM,should the gap be remeshed to solve this problem? 3,if I considered the fluid in the gear side panel, should this fluid be meshed alone, and should this part in CFX-Pre connected with fluid in the gear gap with the "interface" method? 4,what's the main parameters that affect the result? momentum source scaling factor? the single step solving accuracy? others? |
May 5, 2012, 07:21 |
Rep Power: 143 |
1. If you expect the flow to reverse then an opening. Otherwise an outlet.
2. What is the "circle of gears" and "boundary fluid"? 3. What is the "gear side panel"? 4. The issues are described here: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
May 5, 2012, 09:06 |
#3 | |
Stefan
Rep Power: 14 |
March 4, 2017, 03:05 |
Rep Power: 16 |
For those who are interested in gear pump simulation, refer to this link: http://fetchcfd.com/view-project/629
cfx 13 |
Centrifugal Pump Simulation Problem! | warex | FloEFD, FloWorks & FloTHERM | 29 | September 23, 2014 10:27 |
Problem with pump simulation using Solidwork 2010 | nurul_msia | Main CFD Forum | 0 | November 22, 2011 10:03 |
Generated Rotor(G-rotor) type oil pump simulation | Abhishek Thakur | FloEFD, FloWorks & FloTHERM | 1 | November 17, 2011 09:56 |
Peripheral pump CFD simulation | Nevel | Main CFD Forum | 0 | October 8, 2009 01:09 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
