LES Simulation for incompressible internal flow |
March 23, 2017, 03:01 |
Hi All
I am trying to do an LES Simulation for internal incompressible flow and I am getting some errors although I am intializing with zero veloctiy and inlet pressure Also I am getting some error after initializing with the velocity and pressure as my inlet pressure My case is Inlet BC'n : Pressure : 6 bar Outlet BC'n : Massflow rate : 0.058kg/sec Ref Pressure : 1 atm Initialization done with u,V,w = 0 m/s Pressure (Relative ) = 6 bar This is what I got as an error below _______ COEFFICIENT LOOP ITERATION = 2 CPU SECONDS = 8.578E+02 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255. No results file has been created. | +--------------------------------------------------------------------+ End of solution stage. _______ This is what I got . Thanks |
March 23, 2017, 05:42 |
Rep Power: 143 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
Pipe Flow Simulation | comingdaytime | OpenFOAM Running, Solving & CFD | 3 | July 27, 2016 10:40 |
Internal Flow Not Enough Turbulent - (pisoFoam, LES, sub grid models) | vut | OpenFOAM Running, Solving & CFD | 5 | September 15, 2014 14:18 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 14:11 |
