Materials Radiation properties: scattering and absorption coefficient |
April 7, 2017, 07:03 |
Davide
Rep Power: 9 |
Dear all,
I am trying to moodel a solar receiver using CFX. The model is composed by both solid and fluid domains. I would like to set radiation properties for different medias but it is not clear to me what's the order of magnitude of the absorption coefficient and scattering coefficient. I am using Montecarlo ray tracing and according to guide these two coefficients represent somehow the absorption and scattering probability. I am used with kirchoff law so I would have used a value between 1-0. Nevertheless, the frame require a value with units [m^-1]. On-line libraries give the following values in example: Copper abs. Coeff: α = 5.9526e+5 cm-1 using these values the simulation crashes after few iterations. What am I doing wrong? what's the order of magnitude of these coefficients? Also I would like to define an absorption coeffient with different values depending on the wavelenght in vacuum. how can I do it? I read something about step functions, can someone give me an example? Thank you ! |
absorption coefficient, cfx, scattering coefficient, step functions, thermal radiation |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
