Material properties (molar mass)
Old   May 1, 2017, 08:07
Default Material properties (molar mass)
Shabi1992 is on a distinguished road
Hello everyone,
I am trying to simulate the internal flow which the fluid is not exist in the material table in CFX. I don't know the molar mass and I can't calculate it as well. The flow is not very complex and there is no chemical reaction.
So now is it important to enter the molar mass value? Is it true that I run my project with molar mass = 1 ?
Best regards,
Shabi.
Shabi1992 is offline   Reply With Quote
Old   May 1, 2017, 09:25
If your fluid is simple (for instance: incompressible and constant properties) then you don't need to molar mass and can use anything.
If you are not sure just do a sensitivity study and find out. Run a model with molar mass = 1 and another with it =1000. Compare the results and see if it makes a difference.
Old   May 1, 2017, 10:52
Erik
evcelica is on a distinguished road
The program only uses molar mass in calculations that require it: Molar fractions of mixtures, ideal gas calculations, etc. It is ignored otherwise. But like Glenn says, it's always best to prove this to yourself with a sensitivity check.
evcelica is offline   Reply With Quote
Old   May 2, 2017, 08:48
Thank you very much.
Old   May 2, 2017, 08:49
Thank you very much
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Adding material to CFX material library marlon CFX 2 October 16, 2016 10:33
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Fluent is not accepting Modification in Material properties er.mkumar FLUENT 0 September 1, 2012 15:24
