how to show the particle deposition spots?
Like Tree1Likes
  • 1 Post By kingjewel1
Old   June 3, 2011, 16:58
Default how to show the particle deposition spots?
adam2008 is on a distinguished road
I am doing a particle tracking CFD simulation. How can I set up in CFX-post to only show the particle symbols of their final locations (either deposited or flow out of the domain)? I tried everything, adjusting max time, min time, interval etc...
Thanks a lot!
adam2008 is offline   Reply With Quote
Old   June 17, 2011, 10:06
kingjewel1 is on a distinguished road
What do you mean by particle symbols?
kingjewel1 is offline   Reply With Quote
Old   May 23, 2013, 19:58
Liliana de Luca Xavier Augusto
liliana is on a distinguished road
Hello, I have tha same problem!
How can I show only the particles trapped on the wall? And how can I calculate how many particles are trapped?
My simulation is in steady-state and I am using Eulerian-Lagrangian approach.
liliana is offline   Reply With Quote
Old   July 23, 2015, 21:51
jichaoudz
jichaoudz is on a distinguished road
Hello , i meet the same problem - trap and count particle number, Have you solve the problem, can you help me?
jichaoudz is offline   Reply With Quote
Old   July 24, 2015, 09:23
I didnt find the solution... sorry!
Old   July 27, 2015, 06:18
This is just off the top of my head...
1. To show contour plots: You need to follow the ice accretion tutorial. I.e. turn on accretion for paticles. This will allow you to show particles as contour plots, either on walls or on planes.
2.To count the exact number on walls you need to do go to: Results>sample>DPM>select walls. Write to file and then this will have a line count. Count the number of lines either manually, matlab or via a shell script in linux to give you the exact number of particles deposited. (This method gives particle coordinates in x,y,z so you can plot these in matlab if you want too).
fresty likes this.
Old   May 10, 2017, 15:21
Patrick
b4kerman is on a distinguished road
Is this really possible in CFX or CFD-Post, respectively? I cannot find any tutorial on ice accretion in the current version of the Ansys package.
Any help to get accretion rates using CFX and CFD-Post would be great.
b4kerman is offline   Reply With Quote
Particle transport and deposition & Drift Flux Model Peter023 Fluent UDF and Scheme Programming 3 April 20, 2021 23:50
Normal particle velocity in particle deposition! Prashanth Fluent Multiphase 1 May 29, 2013 22:30
particle deposition pattern sarah_ron2002 FLUENT 3 January 12, 2011 06:37
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle Deposition in CFX11.0 siavash ghassemi CFX 0 January 10, 2008 09:29
