May 22, 2017, 10:15 |
Importing eps file format in CFX
Aja
Rep Power: 14 |
Is it possible to import output result of Matlab(for example eps format i.e mesh. eps) in CFX? This output result of Matlab is a mesh file. Another question: Is it possible to export output result of Matlab in CFX? Thanks for your help. best. |
May 22, 2017, 19:04 |
Rep Power: 143 |
CFX-Pre has a number of mesh import formats it accepts. I am sure you will find a common one between matlab and CFX-Pre (but it won't be eps, that is a graphics format).
Also the ANSYS meshing products such as ICEM and FE Modeller allow you to import a whole heap other formats. For export, look at the export options under solver manager. |
May 22, 2017, 21:21 |
Mass flow rate imbalance
Ferruccio Rossi
Rep Power: 9 |
I first run a simulation with a very coarse mesh, and the imbalance is very low (0.01 kg/s). Then, I refine the mesh and run it again, and the imbalance increases to 250 kg/s! How is this possible? That imbalance is close to my flow rate in the domain. How can this happen with the fine mesh? Shouldnt it happen when the mesh is coarse? |
May 22, 2017, 21:24 |
Ferruccio Rossi
Rep Power: 9 |
I believe I found something regarding this topic on the solution manual, although I am not really sure.
May 23, 2017, 19:28 |
Svetlana Tkachenko
Rep Power: 14 |
frossi, please delete here and start a new thread
May 23, 2017, 19:57 |
Svetlana Tkachenko
Rep Power: 14 |
aja1345, how did you create the eps file? Do you have any documentation about this kind of format? Please tell.
May 23, 2017, 20:20 |
Ferruccio Rossi
Rep Power: 9 |
I am sorry, I tried to delete it but i dont know how!
I was trying to post it as a new thread, but i accidentally posted here. How do i delete the post? Again, i apologize it wasnt intentional. |
May 24, 2017, 00:58 |
#8 | ||
Aja
Rep Power: 14 |
I don't have created the eps file. This format is created by my friend in Matlab. We are working on a research project. Do yo know what is the format correct for this case? Quote:
Thanks for your answer. I investigated your statement. But I don't know what is the format correct for this case. Please guide me more. |
May 24, 2017, 02:21 |
#9 |
Maxim
Rep Power: 12 |
I assume your friend exported a graph from Matlab? Is it a 3D graph?
*.eps is, as ghorrocks said, a graphics format (Encapsulated Postscript). I doubt that you can import an *.eps file as a mesh. Why don't you describe what your goal is and add some screenshots and/or further details so that we can help you better? |
May 24, 2017, 03:06 |
#10 | |
Aja
Rep Power: 14 |
MY friend has written a Code in Matlab(flow around an airfoil). This code is a mesh file as follows(Please see the following picture): Now, I want to import above file in Fluent or CFX and run. Thanks. |
May 24, 2017, 04:01 |
#11 |
Maxim
Rep Power: 12 |
I see. But I don't think CFX Meshing can handle *.eps files. Two ideas though:
1) you could try ICEM / convert the eps into a file that ICEM can read. 2) you could try importing the vector graphic (eps) into a CAD program like SolidWorks and then go back into CFX Design Modeler/meshing from there. It might be that this only makes sense for the airfoil profile and you have to to the meshing in ICEM/CFX meshing anyway... |
May 24, 2017, 04:11 |
#12 | |
Aja
Rep Power: 14 |
Do you have any idea that Which is the format of Matlab correct for importing in CFX or Fluent? Matlab can create the following formats: https://www.mathworks.com/help/matla...e-formats.html |
May 24, 2017, 07:51 |
#13 |
Maxim
Rep Power: 12 |
I doubt that there's a direct way.
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
