CFX-5: Output in a console window
Old   April 23, 2002, 10:04
Default CFX-5: Output in a console window
cfd guy
Hi everybody,
I want to run CFX-5 from the console, preventing the graphical residual monitor which consumes some memory, and I don't get the output of the running solution (residuals in text mode, only values) in my console window which I originally called the CFX-5 solver. I suspect that there may exist an extra parameter not shown in the manual. Well, this is how I call the solver:
cfx5solve.exe -def [file] -ini [restart_file]
I've tried the -v (verbose) option but I didn't get any output in the console window. So, any hints?
Sincerely, cfd guy
Old   April 23, 2002, 22:14
Default Re: CFX-5: Output in a console window
Robin
Firstly, for all the solver options type "cfx5solve --h"
The solver is put into the background automatically, so you cannot get a live update. The output is written to the out file during the run (look in the temporary subdirectory runName_001.dir/out ). If you wish to view the outfile as it updates, use the unix tail -f command. The -f flag tells it to follow the file as it updates. If you are on NT, download and install cygwin to get tail and other unix commands.
Robin
Old   April 24, 2002, 08:11
cfd guy
Thanks Robin,
I work on NT and I've tested the tail command under cygnus and worked very well. I forgot to tell. This doubt also apply to CFX-TASCflow.
Suggestion: Perhaps in the next updates of CFX-5 and/or CFX-TASCflow we can get an option like this:
cfx5solve -tail or tascflow3d -tail , etc...
Regards, cfd guy
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 06:30
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
Does CFX can output ".rth" file? prayskyer CFX 6 July 7, 2006 20:08
is "double precesion output for cfx" default? charles CFX 3 May 17, 2006 14:40
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
