Export CFX from workbench to a standalone file |
Dim. G
Rep Power: 7 ![]() |
Rep Power: 134 ![]() ![]() ![]() ![]() |
Have a look in the workbench directory structure for the file. It does exist as a stand alone CFX file, but it is a bit hard to find. The structure is a little complex but with a little thought you should figure it out.
Dim. G
Just for those who will look at this in the future,
here is the solution. 1) You open the workbench directory folder. 2) Go to dp0 3) Then to the corresponding CFX folder 4) Again open the CFX folder 5) There you will find 4 files, i) A .cfx file which is the the cfx pre file ii) A .def which is the solution file (which what I need in my case to give to the server) iii)A .res file which is the results file (a.k.a CFX-Post) All these are stand alone files and you can with them separately. Hope this helped! ![]() ![]() |
Display Modes | |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
