Help: 2D model in CFX 5.5
Old   July 22, 2002, 12:13
Default Help: 2D model in CFX 5.5
Dejun Jing
I hope to reduce my 3D model to 2D model to save the computation time. Now I use a B-rep sold to represent a 3D cylinder. I hope to rebuild a model in a 2D asymmetric model. However, is seems that CFX 5.5 Builder can not build 2D model.
Is this true that CFX 5.5 only generate mesh for 3-D solid?
Thank you very much.
Old   July 24, 2002, 00:25
Default Re: Help: 2D model in CFX 5.5
Michael
You'll need to create a cylinder slice that is only one element thick. You should use the Patran meshing tools to do this (change the Meshing Mode). You can download documentation on using the Patran meshing tools from the CFX community site. Regards, Michael.
Problem importing watertight model into CFX djk1301 ANSYS 3 February 1, 2011 22:04
where to set CFX Transition Model? steven CFX 6 January 17, 2007 11:19
CFX to model convection cells FER CFX 4 December 13, 2006 00:57
Does CFX can calculate within structure model? prayskyer CFX 9 November 28, 2006 23:13
Use of 1 equation turbulence model in CFX 4.3 Niels Deen CFX 0 July 19, 2000 08:50
