Fin flapping in CFX
Old   August 1, 2017, 09:23
Default Fin flapping in CFX
Shyam123 is on a distinguished road
Hello everyone,
I have been working on a Project based on MantaRay and my Task is to simulate the fin flapping of the Manta and simulate the same and analyse the results.
I have created the geometry in SOLIDWORKS and the mesh in ICEM, I have imported the mesh into CFX but i am not able to find a way to move the fins.
It would be really helpful if somebody can help me in this regard.
Best regards
Shyam
Shyam123 is offline   Reply With Quote
Old   August 1, 2017, 20:35
This sounds like a moving mesh application. Have a look for the moving mesh tutorial examples on the ANSYS customer webpage, and read the documentation on moving mesh.
Old   August 2, 2017, 06:50
Thank you for the Response.
The method I have to follow is Immersed boundary method so it is not a Body conformal method.
Is there any way I can define the Motion and apply the immersed Body conditon in CFX.
Regards
Shyam Prithvi
Old   August 2, 2017, 07:51
You could do it with immersed solids. The advantage of this is you can have a high quality mesh and impose a very complex motion on it and have no problems with mesh folding. The disadvantage is that you cannot resolve the boundary layer with a fine mesh and you can't use inflation layers.
So if accurate resolution of the boundary layer is required then you have to use moving mesh. If not then immersed solid is OK.
On second thoughts - immersed solid is a rigid body modelling tool. The solid must be rigid, but it can translate and rotate. So you cannot model the flapping wing of a Manta Ray. You might be able to approximate a flexible body by having many small rigid bodies and moving them to approximate a flexible body - this sounds difficult to me.
I suspect you are going to have to use moving mesh.
Old   August 2, 2017, 08:02
Yes, I have divided the fin into small segments to give the movement.
Can you please let me know how to define the movement of the fin.
I have the equation and the input values to define the movement but I cannot find any tutorial as to where I have to put these to get the desired movement.
Regards
Shyam
Old   August 2, 2017, 08:10
There is no tutorial on this. I do not even know if it can be done. You are going to have to work it out yourself based on the rigid body motion stuff which is there already.
Old   August 2, 2017, 08:15
Thank you for the response.
Regards
Shyam
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
Flapping fin thrust in FLUENT jinks FLUENT 2 July 19, 2013 20:34
The problem of inner iteration when calling the subroutine guoxj CFX 18 October 23, 2010 21:37
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
PhD using CFX Rui CFX 9 May 28, 2007 06:59
