How to modify gas constant or special heat ratio in CFX-Pre? |
August 24, 2017, 00:58 |
xuhaoyang
Rep Power: 8 |
I must modify gas constant or specific heat ratio in CFX-Pre.
Because I investigate the effect of fuild property, such as operating characteristics when the gas constant is constant and specific heat ratio is different. Thanks |
August 24, 2017, 05:33 |
Jiri
Rep Power: 13 |
If you modify molar mass M, you also modify specific gas constant r (r=R/M), so you modify also heat ratio Cp/Cv. See Mayer's relation for gas (Cp = Cv + r).
August 24, 2017, 06:49 |
Could I modify directly gas constant or specific heat ratio in CFX-Pre?
xuhaoyang
Rep Power: 8 |
August 24, 2017, 09:22 |
Rep Power: 32 |
You cannot modify the specific heat ratio, nor the gas constant directly in CFX-Pre.
May I ask what is your goal changing the gas constant, and/or the specific heat ratio? It seems you are making an assumption those quantities are used inside the software somehow. From what I understand, they are not used anywhere explicitly. You can rewrite the fundamentals in reverse R_gas = R_universal / Molar Mass ---> Molar Mass = R_universal / R_gas which you can change at will Cp - Cv = R_gas Cv = Cp / SpecificRatio --> Cp = SpecificRatio * R_gas / (SpecificRatio - 1) Hope the above helps, |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Thermally coupling 1D gas flow to 3D heat conduction in solid | Pyotr | CFX | 5 | March 6, 2017 21:46 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Convective heat transfer issues in CFX | techtuner | CFX | 30 | May 14, 2016 09:55 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
