Difference between sum of energy input and total energy |
September 8, 2017, 09:01 |
Rep Power: 8 |
Hello evereybody,
I try to modell the heating process of an electrical boiler with cfx. The model itself is very simple. I modelled half of the boiler without any inlets and oulets and put on symmetry at the cutting plane. The energy (1,5kW) is put into the model as a heatflux over a defined area and the buoyancy is included in the model too. I started the transient analysis of the heating process with 15 timesteps over 9000s. After the calculation i checked the enthalpy difference between the first and last timestep and compared it to the theoretical delta h (1,5kw*9000s/fluidmass). I found out that there was 20% more energy in the model than expected. After that, I refined the mesh at the heating input and started a calculation with 150 timesteps over the 9000s. Result: 15% less energy than theoretical calculated. What causes those differences? How can i improve the accuracy of the total energy? Do I have to reduce the timestep size signifficantly? For this comparison i used a very rough mesh (6.000 nodes). But I had the same problems with another mesh (100.000nodes) Thanks in advance Luis |
September 9, 2017, 06:50 |
Rep Power: 143 |
Transient energy conservation | dvcauwe | OpenFOAM Running, Solving & CFD | 1 | April 24, 2014 13:48 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
Don't know where energy lost from my domain | Atit Koonsrisuk | CFX | 2 | March 29, 2005 06:30 |
