Qs on symmetry of flow field, conducting solid
Old   November 11, 2002, 11:06
Default Qs on symmetry of flow field, conducting solid
boji
hello there,
I'm modelling a gas combustion furnace, a horizontal cylinder with a burner in one end in the center, and outlet in another end. And I'm using CFX 5.5.1.
Q1, I found the flow field is not symmetric. Is there anyone else experienced the similar phenomena? What can I do to improve/correct this? (I'm not going to use a 2D simulation.)
Q2, If I consider a conducting solid (Fireclay) around the furnace, heat transfer coefficient BC. With a small timescale for "energy" equations, it would converge with a wrong T field. While if I apply a larger timescale (e.g. 10s), the convergence is very slow. I played around with "Solid time scale factor" etc., there was little help. Could anybody give me some suggestions on this?
Thanks in advance.
bo
Old   November 11, 2002, 17:08
Default Re: Qs on symmetry of flow field, conducting solid
Astrid
Q1. When you unstructured grid is not symmetric, your solution will not be completely symmetric.
Q2. Have you tried to run with only the energy equation while using a huge timestep?
Astrid
Old   November 12, 2002, 07:05
boji
Thank you.
I thought solving a heat conduction problem would be fast.
The calculation is running now with 60s for energy equations and 1s for the others. The RMS for energy in solid is about 2.3*10^-4 and converging very slow (rate=0.99 or even 1.00). Energy imbalance is about 50% in the solid area but decreasing slowly. Any more suggestions?
I found out that you also attended the conference in Strasbourg, in an earlier post. Do you have any news of the CD?
Best regards bo
Old   November 12, 2002, 14:17
Neale
Run with an even higher timestep on the energy equation, like 1.0E20. If the heat transfer is diffusion dominated it may take quite some time to converge with a small timestep.
Also, what is the Prantdl number for your fluid? If the thermal boundary layer is much thicker than the hydrodynamic (i.e. Pr>>1) then you will have to use quite large energy timesteps.
If the fluids equations are solved well enough then you might also try turning them off with the "solve fluids =f" (maybe also solve tke eps=f) expert parameter and then just solve the energy equation with that large timestep.
As far as the symmetry of the flow field goes, how were you ensuring this? Did you use symmetry boundary conditions? If not, then symmetry is not guaranteed.
Neale
Old   November 12, 2002, 17:31
Astrid
No news of the CD. Ask the helpdesk.
Astrid
Qualitative Observations of Mean Flow Field Josh CFX 4 July 9, 2010 16:52
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 10:14
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
