CFX solver return code 255 on win10 server
Old   September 24, 2017, 01:31
Default CFX solver return code 255 on win10 server
Cyrus
BigCatDairy is on a distinguished road
Send a message via Skype™ to BigCatDairy
Hey guys
Got a problem when i was doing a fluid sim today - I setup everything in CFX pre then go to the CFX solver, windows with error messages poped up as * below.
I guess it cause be incorrect parallel setting because the calculation was find in serial mode.
* The ANSYS CFX solver could not be started, or exited with return code 255; .No results file has been created.
* CFX_003 has terminated with errors. Run concluded at: "date"
No results are available
* Update failed for the solution component in CFX. The solver failed with a non-zero exit code of : 2
Any feedback will be appreciated
PS: the same task was run normally on my old computer @ e5 3470, but lately i upgrade to a E5 server with 20 core, 32GB ram to go faster, the setting and everything else were the same.
BigCatDairy is offline   Reply With Quote
Old   September 24, 2017, 02:20
Cyrus
some screen snap shots
Old   September 24, 2017, 05:22
Amr Mostafa
Umro mostafa is on a distinguished road
hi Cyrus ,
i suggest to you to
1-check the mesh
3-if the problem transient ,check the total time you entered
2- re setup the problem and save the project before running OR make a new project with the same parameters and settings
i face this problem when i make changes on the the setup and make run , this massage appear after a few iterations , but when i make a new project the problem is solved.
Umro mostafa is offline   Reply With Quote
Old   September 30, 2017, 01:37
Cyrus
Originally Posted by Umro mostafa View Post
hi Cyrus ,
i suggest to you to
1-check the mesh
The problem was solved by redoing all the project from modeling, that was whole bunch of work but finally solve the problem.
thank you very much for help.
CFX Solver Manager Error Code 1 Peta247 CFX 3 June 4, 2016 11:00
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
cfx exited with return code 1 - more details... Luk_Fiz CFX 7 September 1, 2014 01:53
The Ansys CFX Solver exited with return code 1 Basavaraj CFX 1 February 10, 2014 02:30
Error 255 in ANSYS CFX solver safacity38 CFX 4 May 21, 2012 03:43
