compressible problem
Old   February 24, 2003, 04:47
Default compressible problem
hx
Hello, everyone, I am useing cfx 4.4 to simulate the reactor. I want to simulate the solution for different. I use fully compressible flow and use database. I donot know how to set the parameters for these. Who can help me?
Best regards,
Haoxu
Old   February 24, 2003, 12:04
Default Re: compressible problem
matej
Maybe if you could be more specific, as what reactor? Is it nuclear one, chemical one?
generaly - if you define SPECIES for reactions (supposing you not model nuclear reactor), and you specify PCP database, than you can set the species with :
>>MATERIALS DATABASE
>>SOURCE OF DATA
PCP
>>FLUID DATA
FLUID 'AIR'
MATERIAL TEMPERATURE 3.0000E+02
MATERIAL PHASE 'GAS'
>>SPECIES DATA
CH4 'METHANE'
under >>MODEL DATA.
I found it if examples, anyway.
matej
Old   February 24, 2003, 20:18
hx
Hello,Matej,
Thank you for your quick and good response. I am simulating spinning basket reactor used for the evaluation of catalyst, a chemical reactor. The medium in the reactor is air, and I use the use database. I want to simulate the situation for reactor in different pressure, such as 2.0Mpa. I set air is fully compressible. Certainly, the density is different, I donot know how to set the parameters for compressible flow, how to set the reference pressure, and how to set the inlet patch. Really thank you again for your help.
best regards,
Haoxu
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
Problem calculate Y in compressible turbulence model luca OpenFOAM Running, Solving & CFD 5 June 1, 2006 05:53
I have some problem about Compressible Cruger FLUENT 4 December 5, 2005 07:05
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 04:58
