November 3, 2017, 09:38 |
error message on setup cfx
Hamid Arakey
I’m simulating annular tank filled 60% of water with horizontal excitation but always when I finished from setup get tow error below:
1- In Analysis 'Flow Analysis 1' - Domain 'Default Domain': Mesh motion is specified on the boundary 'opening'. This is valid for motion that is tangential to the boundary but solution errors will occur if motion is normal to the boundary. 2- In Analysis 'Flow Analysis 1': Export results are unavailable as no suitable boundaries exist for use as export surfaces. Mesh motion on a boundary invalidates its use as an export surface. Any help will be greatly appreciated! Thanks hamid |
November 3, 2017, 23:05 |
Rep Power: 143 |
It is a warning, not an error. It is not stopping you proceeding.
And if you read the warning you will see that it says tangential motion of the opening is OK. It looks like your opening is horizontal and you said you are doing horizontal excitation - so this is tangential motion so you will be fine to proceed. |
November 9, 2017, 08:28 |
Hamid Arakey
Thank you very much for your reply
November 9, 2017, 12:43 |
Erik
Rep Power: 23 |
For my own curiosity, What is the purpose of the opening anyways? Why not just a wall? does this make the pressure more numerically stable?
A problem with CFX setup | Ahmed Saeed Mansour | CFX | 22 | August 31, 2016 09:41 |
how to setup radiate emissivity in CFX | qihongming | CFX | 1 | August 1, 2016 05:19 |
Oil properties in setup of CFX | rusted86 | Main CFD Forum | 2 | April 11, 2013 10:47 |
How to setup stopping criteria in CFX??? | Saima | Main CFD Forum | 0 | November 21, 2012 20:06 |
Guide setup PVM CFX | painterwolf | CFX | 12 | May 24, 2009 19:47 |
